Steam piping
Weil
Member Posts: 25
Anybody have any experience piping a high pressure boiler with threaded stainless steel instead of welded. I am installing a Lattner HRT 15HP boiler that will operate at about 75 to 100 PSI with a PRV station taking it down to 30 PSI right at the boiler. This feeds a steam kettle about 25 feet away for food processes. I would like to use threaded pipe if possible. I sure do appreciate any responses.
Thank you
Weil
Thank you
Weil
Good luck with that
I don't have any experience with steam at this pressure. However, I did work for a company that used fairly high pressure (60 psi) on water treatment system (large RO filters - 60 GPM). The one system we did with threaded stainless pipe, we could not get to seal watertight . In the end we welded every one of the threaded fittings. Every system afetr that used welded fittings and we never had another problem.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 103 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 936 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
