bench test r7184U
chuck172
chuck172 Member Posts: 90
I'm trying to troubleshoot my primary. I have the cad cell connected and seeing light, Line voltage to L1and L2.
The green light is on, but when I check for voltage at the Burner Motor connection, nothing.
T&T are jumped.
Shouldn't I be getting voltage to the burner motor here?
  • Gordo
    Gordo Member Posts: 857
    edited November 2011
    The Cad Cell
    should start out "in the dark" or disconnected.
    The control should NOT start the burner motor if it thinks there is already a flame being detected.
    Once the burner motor voltage is detected, then quickly connect the cad cell.
  • chuck172
    cad cell
    The burner motor does start with the cad cell disconnected. Then as soon as I connect the cad cell, the primary goes off on reset, the light starts flashing.
  • billtwocase
    billtwocase Member Posts: 2,384
    lock out
    If the control sees light/flame before oil valve is energized by the control. it will lock out. Why are you bench testing the control?
  • chuck172
    why?
    I'd like to know if my primary is shot and needs replacing.
