What is the slowest straight went out there?
malex
Member Posts: 106
I have one of those retrofitted radiators with a sheetmetal front and fin-tubes inside in a small bedroom. It gets very hot quickly but doesn;t hold the heat as the cast iron radiators. I don't want to turn it off so I want to went it as slowly as possible and use an additional heat source if necessary to keep to room warm when this radiator stops giving off heat. It uses a straight connection and I actually have a brand new hoffman 41 laying around. Is that any good? I have Gorton 4's on half of my radiators and 5s/6s on the other so preferably I would have went that is even slower than the 4's.
Any suggestions?
Any suggestions?
Try pexsupply.com
I have ordered straight Gorton D's from them. They likely have the slower ones as well. Gorton #4 is pretty slow.0 -
Hoffman 41
When we want a radiator to vent slowly, we use Hoffman 40 or 41's.
Gerry and Steve's research show the Gorton #4 to vent even more slowly. According to their research, the Gorton #4 would be the slowest.
They are both very good quality vents.0 -
I will try the Hoffman 41
I know not to throttle the valve to get less steam but are there any other tools of the trade to slow down/reduce the heat a radiator gives off?0 -
Thermostatic Valve
You can place a thermostatic valve on the vent, with a remote room sensor. The valve would only open the vent when the room drops to a set temperature.
Danfoss makes such a valve, but be prepared with lots of cash to buy it.0
- 167 Indoor-Air Quality
