Need an old wirsbo thermostat - a 508
Longshot
Member Posts: 6
Hi,
I need an old working wirsbo 508 thermostat. One gave out on me and the wirsbo guy said I had to change all the thermostats on one zone and put in a new controller. He wasn't sure but he did not think I had to put in new controllers in the whole house plus all new thermostats. I was hoping someone might have an old 508 on a shelf somewhere. Thanks.
the old wirsbo 508 was and still is made by tekmar controls. you should be able to pick one up at most heating supply places.
http://tekmarcontrols.com/zoning/508.html0 -
Old 508
Thanks for the help, but that's not the old 508. The old 508 is really old. The problem is they never changed the number, just the thermostat. I'll try to send a picture when I get back home from Thanksgiving. Pretty lousy of them to change the thermostat and not the number. This old one was controlled by the 514 controller and I am not sure they didn't keep that number too.0 -
Here is the picture
I know it's old. Built the house 20 years ago. I thought maybe someone had it on their shelf.
Doug0 -
oh
I'd totally forgotten about those, I actually have a 308 in my little heating museum. They have 2K sensors as opposed to the newer 10K, which makes upgrading a pain, you have to change out the main boiler/mixing control too. Have you thought about upgrading?
BTW, technically they are not thermostats but Room Temperature Units. (RTU)0 -
Old Room Temperature unit
By any name it's the same pain. I have thought about changing everything out, and it makes me shudder. I still don't know if I have to change out every control unit in the house, anlong withe every room tempererature unit along with every actuator. The Uponer guy says maybe I can change one zone and it will work, but I can see conflicts with the boiler controls. It's a nightmare, and maybe, just maybe, I can find one on the web.
Doug0
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 114 Geothermal
- 164 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 394 Solar
- 15.6K Strictly Steam
- 49 Job Opportunities
