Delta T ?
alotlikeearl
Member Posts: 68
I know the recommended delta t for baseboard is 20 degrees and radiant floor is 10 degrees; what is recommended for cast iron radiators and cast iron convectors?
What Works
Depends on the application. Condensing boiler would use a Taco VDT pump and work off a 30 if the math works out. Might do the same on a cast iron boiler depending on whose it is. Am I using outdoor reset on the system?There was an error rendering this rich post.
Thanks Chris,
I have quoted both a modcon and a cast iron boiler. If they go cast iron I probably would not use outdoor reset and just let the "VDT' circulator do its thing. This system has 4 zones total; 1 cast iron radiators, 2 cast iron convectors and 1 baseboard. I was hopeing a common delta t would work so I could use 1 "VDT" and zone valves.0 -
Only Way
To anwser that is to take your room by room heat loss, break it out to the zones and do the math. Can I overcome all zones heat loss running a 30?There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
