ARE BOILER VENT DAMPERS INTERCHANGEABLE?
Hi guys:
I have a CG-6 gas boiler and it needs a vent damper. The guy at my supply house who can be helpfull but can also be an idiot gave me one for a Crown (6" FLUE) and says they are interchangeable. I seem to think they are, as there is only one way to plug the harness in (I THINK) and therfore the wiring will match up fine.
I just want to confirm the above before I proceed.
    Steamhead Member Posts: 18,205
    If they were actually made by Effikal or Field
    they are interchangeable. Field bought Effikal some time ago.
    But if only the motor is bad, you can replace just the motor. I think the Field part# is GVD-RMA.
    Consulting
