H-well Aquatrol setup
KBP&H_3
Member Posts: 67
I have an installation where there are 3 circs- one primary that runs when either the heat zone or the domestic w/h call for heat, the Aquatrol will run either the boiler ( heat) circ or the domestic- I need to also have the system pump run when either is running, the aux contacts appear to be only controlled by one or the other, I can't find a setting for it to run with both the heat or domestic circ's. ?? Any ideas besides a DPDT relay?
Aquatrol
I'm not familiar with Aquatrol wiring, but you might be able to wire the pump to contacts provided on your boiler.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I think so
If you enter installer mode, you will find there is a setting to determine when the auxiliary pump runs. I believe if you set this to boiler it should do what you want.0 -
Venco Sales
Got it- The local NJ rep Venco Sales and Tom Dryer set me up late Friday- We set the domestic hot water to the valve settimg and switched the aux and boiler circ> The system circ works with either the domestic or heat call-- working great, pre and postpurge , post purge to domestic,, the domestic only ran 2 hrs the last 3 days w/ 5 people and related laundry. Thanks Tom-----0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 944 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
