Burnham Holiday- where's the btu rating?
LukeC
Member Posts: 2
I have an old workhorse of a boiler- a Burnham Holiday. It runs, keeps up with the heating requirements needed in the Rockies, however I am wanting to price out a replacement system. The Boiler dimensions are 21.5"x24.5"x30.5", however I have searched high and low for a btu rating. If it helps, it has a Watts ET-30 Pressurized expansion tank attached to it and was installed in 1972. Our county is kicking in money for boiler replacement, and I would like to potentially take advantage of it. Thanks!
Heat Loss
The rating of the existing boiler is a waste of time nor would any professional replace the boiler without doing a heat loss. Don't worry about the existing boiler. have a heat loss calculated and size the replacement boiler based on the heat loss.There was an error rendering this rich post.
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
