Hydronic toe kick heater
ELH
ELH Member Posts: 1
I have a hydronic toe kick heater under the kitchen counter that is not working. Coils are hot there is power going to the unit what else should I check? Also where can I get a replacement Or parts to fix? I live in central Wisconsin.
  • lchmb
    lchmb Member Posts: 2,997
    is power
    going to the blower motor or is the heat switch not closing? You should be able to get universal parts to repair it depending on what part failed..
