Boiler sends up steam, water returns too slowly, low water cut off comes on too often
Raynic
Member Posts: 13
Water level in steam gas boiler starts out with correct level of water in glass tube. As steam comes up water level in glass tube goes down until low water cut off comes on. Boiler stops, water slowly returns to boiler to correct level in glass tube, boiler starts. The process repeats it self every half hour or so. It seems water returns too slowly so there is not enough water in boiler thus kicking in the low water cut off. Once the water returns and there is enough water in the boiler it starts again. This is a three story townhouse. Could this have anything to do with the steam relief valves on the radiators?
- 117.6K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 402 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 679 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 11 Recall Announcements
