EZ-Gas Cover Part Number?
Hoog23
Hoog23 Member Posts: 19
Does anyone have the part number to the acoustic cover?  Installed on a 4 section G8.
Thanks in Advance!
    Steamhead Member Posts: 18,203
    You need to replace the air tube also
    with one that has the cover mounting flange. The air tube will also be two inches longer, and so will the orifice nipple where the gas valve is mounted.
    Best bet is to call Carlin, or have your contractor do it. Tell them what you have and get the part numbers from them.
    Consulting
  • Hoog23
    Part Numbers
    Thanks - I did end up calling and Carlin gave me the two part numbers below.
    CVRGKITS
    50295K
