hot water zone off a steam boiler
Paul Fredricks_3
Member Posts: 1,557
How much hot water can you pull off a steam boiler? We have a customer with 3 zones and an indirect coming off a plate heat exchanger. They aren't getting enough heat transfer to make the hot water, especially if the zones are running. But if we put a larger plate heat exchanger on, will it keep the boiler from making steam?
I haven't been down there yet to scope it out, just trying to get some background info before I look it over.
RE
Typically no more than 30% of the steam capacity, or the added pick-up factor. The hot water loop should be an after-thought to the size of the steam boiler.0
- 117.6K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 403 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 682 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 12 Recall Announcements
