no heat
yet another case of a pressuretrol set too high and other folks changing radiator vents when all they needed to was explore the root issue at hand.
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    The rest of the story??
    OK, cummon.  Tell us the whole story.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
