Honeywell T-stat
ChrisJ
Member Posts: 15,706
Ok first off I'm somewhat embarrased to post this as I am usually very good at figuring out these things. One of my hobbies is restoring antiques and being careful to figure out things and not damage anything.
However! I have an older Honeywell T-stat with a mercury bulb which is gold in color and has a plate on the wall. I cannot figure out how to remove the t-stat from the wall or tweak it as far as leveling goes. I've been told by several people that this thermostat is actually pretty good for steam heat so I'm planning on keeping it. Is this large round plate behind it optional? I have the anticipator set all the way up on 1.2 which I believe was recommended for steam.
Though this picture is from before we owned the house it shows the t-stat.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
RE
Pop off the round ring by hand. There should be 3 set screws to loosen, but they won't come out. One is hiding behind the mercury bulb.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
