geothermal start up
robert borders
Member Posts: 48
seasoned HVAC mechanic and owner doing a geo for the 1st time and need some advice which may "seam too easy", but even columbus had trouble in the beginning finding this new world but once you know everything is easy~!
i have a 5 ton 2 stage hydron module with 5 -3/4 loops out 230 ft and back each to 2 each S & R 1 1/4 lines into the home which are to be horizontally drilled. planning on putting Methanol in the loop. where can i get a safe pump to get the methanol out of the 55 gallon drum? 2ndly, i have purchased a glass monmeter but have no idea how to read it.[help] Last of all, what would you think it would take in total gallons of the anti-freeze, so as i can only take what i really need to the job site?
thank you
<a href="mailto:rlborders@iowatelecom.net">rlborders@iowatelecom.net
Bob Borders West Point, Iowa 319-795-0822</a>
thank you
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
