IBR baseboard ratings
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,621
<span><span style="color:#000000">I heard the
most recent IBR residential baseboard rating catalog has a “Table E” in it that you can use to take the
IBR tested data at 150F down to other temperatures such as 100, 110, 120, 130 and 140.
Does anyone have this Table E, and if so, could you share it with me? Thanks!</span></span>
Retired and loving it.
  • JStar
    JStar Member Posts: 2,752
    RE
    Not exactly what you're looking for, but I have this graph...
    Just a few calculations get you the same numbers.
  • DanHolohan
    Thanks.
    I've got that, but I'm not sure if it applies to baseboard. When I heard about that new table I wanted to see if it agrees with what you've shared. Thanks!
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,568
  • DanHolohan
    That helps. Thanks.
    Still love to see that new table if anyone has it.
  • PeterNH
    PeterNH Member Posts: 87
    Table C?
    Hello Sir.
    I've searched for the illusive Table E and have never been able to find it.
    I have found a Table C, which I'm sure you already know about.
    But just in case:
    TABLE C
    Factors Used to convert I=B=R Steam Ratings to
    Hot Water Ratings at Temperature Indicated
    Average Radiator
    Temperature Factor
    100..............................................................................0.15
    110.............................................................................. 0.20
    120..............................................................................0.26
    130..............................................................................0.33
    140..............................................................................0.40
    150..............................................................................0.45
    155..............................................................................0.49
    160..............................................................................0.53
    165..............................................................................0.57
    170..............................................................................0.61
    175..............................................................................0.65
    180..............................................................................0.69
    185..............................................................................0.73
    190..............................................................................0.78
    195..............................................................................0.82
    200..............................................................................0.86
    205..............................................................................0.91
    210..............................................................................0.95
    215..............................................................................1.00
    220..............................................................................1.05
    225..............................................................................1.09
    230..............................................................................1.14
    235..............................................................................1.20
    240..............................................................................1.25
    http://www.ahridirectory.org/ahridirectory/pages/ftr/I=B=RFinnedTube.pdf
    Peter
  • DanHolohan
    That could be it.
    Thanks much!
  • CMadatMe
    CMadatMe Member Posts: 3,086
    Dan
    Try this.
  • DanHolohan
    Here it is!
    With thanks to Slant/Fin's Keith Muhlmeister.
  • PeterNH
    very Interesting
    Thank You Dan.
    Notably lower than the Table C factors.
    Peter
