VALVE HEIGHT
JAR
Member Posts: 2
Is there a standard height for a shut-off valve. The Gov-Free is 2 1/2" but my valve is at 3 1/2" I cannot crib up the radiator because it would block the window (yes i know it is only 1" more) I need a shorter one I could crib up or a different brand that has a higher steam input.
or you could lower the valve
You would get more responses in the steam section.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
