CO monitor wired into appliance...
KeithC
Member Posts: 38
I was browsing through Kele's catalog a while ago and saw a line voltage CO monitor that had a SPDT output. I figured at the time that it would be a worthwhile safety control to wire in series with your limits; if there was a CO condition in the boiler room, the output can shut down your appliance and signal an alarm if desired.
Anybody use a similar control on any of their installations? Curious to know if there are any recommendations.
Keith
Keith
CO
I thought I heard a while back that there was one of the SPST type that you could wire in series w/the service switch for the appliance (120v) not sure if ME or Timmie had mentioned it, either way its a good idea.0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
