Hot Water Rads
Greg Maxwell
Member Posts: 212
Those look...
Like Weil-Mclain Cabinet rads.... they are listed in EDR.... got dimentions?0 -
Weil McLain Cabinet Raydiant
I agree w/kcopp, I'm trying to scan the pages from my EDR book, if i have any luck ill try to post them0 -
Rads
That is exactly what they are Mikey, thanks for the help. Its always nice to see something new out in the field. Id actually like to be able to sell these now. They are an awesome system, convector and radiator in one. You ought to see the W/M boiler running it! Its an old 77 series, everything original, excet they retrofitted a Beckett to it. Even the B&G pumps are original!0 -
Rads
No problem Greg, they are some cool looking rads, post some more pics of the whole system if you get the chance0 -
Hot Water Rads
This was truely a great job. It is alsot a shame to change out that boiler, everything (to me anyway) is artwork. All threaded pipe, all properly insulated, the system still had the original limit control, flowchecks, pumps, even the original water feeder. But, you could throw a cat though the passages of the boiler, and I could smell soot the moment I walked into the basement. The clean out doors were never sealed. So, there hopefully will be a new Biasi SG boiler in its place that will run at 86-87%, with a H/W AQ251 control, outdoor reset, and modulated water temp to the rads. Should be a nice system when its done. Thanks all for the help.
Greg0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
