hw series boilers Pump Taco
eltoum
Member Posts: 1
i have Hw series boiler can i use heatmaker circulator pump part # 2400-005
as the pump on part # 2400-004
<a href="http://www.heatmaker.com/Heatmaker-2400-004-pump-Circulator-with-Gaskets-p/2400-004.htm">Heatmaker 2400-004 pump, Circulator, with Gaskets (Grundfos), with pressure differential </a>
since the model i have does not use pressure differential switch.
my boiler model # is 130HWNAT
2ND QUESTION
I CHECKED THE AC 120 VOLTS SUPPLY ON THE BUE WIRE SUPPLY FOR
HOT WATER PUMP AT THE RELAY BUT THERE IS NO VOLTS the relay has 8 pins three at left side ,three at the right side and two in the center, the blue wire for pump supply is connectted to the third wire at the left at the buttom is it coorect and if it is not orrect where should it be connected ?
i will be happy if you send detailed cicuict diagram for the three relays showing pins numbers abd wire color.
with my best regards to all heamakers staff and all heatmakers users
your sincerely
Mahgoub Eltoum
phone # 908-576-6321
2ND QUESTION
your sincerely
Mahgoub Eltoum
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
