riello air damper
Paul_69
Paul_69 Member Posts: 251
anybody change the new air dampers on the riello f40 residential burners. any tricks or info on changing out. thanks
  • billtwocase
    billtwocase Member Posts: 2,384
    are you talking
    the motorized air shutter? Haven't had any problems as of yet. The hydaulic jack type would weep some after time. Is that what you mean?
  • Paul_69
    riello dampers
    no the new electric operated air dampers
  • billtwocase
    The ones I have
    out there have been working fine. They do need to be wired right
  • ChasMan
    ChasMan Member Posts: 476
    edited October 2011
    Electronic shutter.
    Was it recently redesigned? I know no one has an issue with them except they wear out and you slap a new one on for 150.00 every couple of years when they start spinning round and round.
    In my case, that switch held the burner on untill it went off on high limit. It was a bear to troubleshoot it too. I jumped it out and removed it. I'd be willing to replace it if Reillo redesigned it.
    After opening it up and disecting it, it is by far the worst piece of electrical crap I have ever seen. Those 2.00 light switches they sell for residential are made better. They are not safe in my opinion.
    If you do use one, make sure to power it after all the safety's and make sure you trust your high limit control. You may need it.
