System Critique – Supplemental Under Floor Radiant Heat
HFC
I installed a AO Smith Vertex water heater and
I am now ready to order the rest of the supplemental heat system for our master
bath tile floor. The Uponor JoistTrak has already been installed, but I found a
manufacturing defect in the 200 feet of 1/2” Uponor hePEX I installed so it needs
to be pulled and replaced.
Below is a diagram I put together from the installation
instructions for the AO Smith Vertex and the Taco X-Pump Block. I will order a three
or 4 port manifold, but will only use one port for now. If I am satisfied with
the results with the supplemental heat for the mater bath, I will consider
adding more supplemental heat zones.
Have I illustrated the system correctly? Do I need an <span style="color:#170A06">Actuator if I am only running one zone now?</span>
Thanks for taking the time to read my post and consider my questions.
<img src="http://www.fototime.com/4F409B22FDAB482/standard.jpg" width="640" height="225" alt="" />
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
