Aquapex and Hepex
Plumdog_2
Member Posts: 873
Does Aquapex really not have an Oxygen Barrier, or is it just the approval and marking stripe? Just curious.
No O2 barrier.
Only the HePex has it. I have seen what happens when it is installed in a radiant application... not pretty.0 -
Along these same Lines
Several times, I have isolated non-barrier radiant systems from Iron-Steel boilers and components with plate heat exchangers and all non-ferrous on the non-barrier side. Does anyone have a good method for flushing/treating they would be willing to share? Once the rust gets severe, it kinda hangs around. Some kind of cleaner (that works) would be great if anybody knows?!0 -
Just had to...
clean a system that had heat-way onyx tubing.... supposed barrier but not. Flushed out system w/ lots of water, added Rohmar 9100. System will run for a few weeks then I will flush out w/ water again and add the 922.
http://www.rhomarwater.com/products/residential-hydronic-radiant/
Unfortunately the circulators were toast.0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
