Small renovation: replace 1930's radiator with?
ibilisi
Member Posts: 2
Hello all, I need some help deciding on heating options for a small renovation that will remove an old cast-iron radiator.
Main question is, do I utilize a "staple-up" system to heat the space or utilize a series of Runtal or similar panel radiators? My wife would prefer the staple-up but I'm not sure that is the best way to proceed. Additional information below. Any help/thoughts is/are appreciated!
Note that additional insulation to wall cavities will take place later this year or early next.
Garret
I am adding a door to my kitchen, which will move a cast-iron radiator that is 660mm tall and around 27 fins. Estimate that to be ~6700-6900 BTU (based simply on an online calculator so possibly useless). Floor of kitchen is linoleum over 1" tongue and groove.
I am also adding a small pantry and bathroom.
Kitchen is ~8'4"h X 9'w X 16'l
Bath/powder 8'4"h X 5'w x 6'l
Pantry 8'4"'h x 3'w X 4'l
These rooms are on the north side of my house, built 1930, true 2x4 walls with no cavity insulation, Minneapolis MN.
I plan on adding either CCspf or Cellulose to cavity during renovation. Other walls in the house will have to use cellulose and will do so after renovation is complete.
I am in the process of removing the old basement ceiling to the joists and will have access. Basement is not insulated at this time, on tap is 2" XPS on floor ~R20 on walls (basement insulation wall build not decided).
Boiler is a 1960's boiler, iron radiators.
Garret
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 391 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 44 Industry Classes
- 48 Job Opportunities
