First Company VFD Air HAndler Wiring
meatball
Member Posts: 5
installed, have the RC (blue wire from tstat) going to R on the unit. AC works.
Have RH (red wire from tstat) that is hanging out there (no connection)
Wiring diagram is weak.
I can make heat or ac work individually but not via the tstat switch.
Anyone have an idea how to make this work?
switching relay
Try a SPNO swich relay. RH-C to coil side dry contact side to your heating control.0 -
Wiring
The power for the 24v control wiring goes from the hot side of the xformer TO the "R" terminal in the AHU ,then from "R" terminal it goes TO the t'stat "RC" terminal, then from the t'stat "Y" terminal the power goes BACK to the AHU "Y" terminal and on to the AC. Then, IF, the heat has it's own 24vac xformer then the hot side of the heat xformer goes TO the t'stat "RH" terminal (NO jumper between RC -RH) and then BACK to the heat thru the t'stat "W" terminal. OR ,depending, a relay at the heat xformer can control the heat thru the relays contacts. And then back @ the t'stat put IN a jumper from "RC" to "RH" then the( AHU 24v power) power goes thru the "W" terminal to the (heat )relay coil. Or a few other ways.
What is the heat source?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
