Bleeding Wayne Mod M-LS Mobile Home Furnace
Joeboo
Member Posts: 1
I have an Older Model Mobile Home Furnace Wayne Mod M-LS used to heat garage. Fuel line is double line system connected to underground tank 80 feet from furnace. I changed
fuel line filter. Now having trouble bleeding even though I filled oil filter canister before replacing filter. Question is what do I place jumper on to so that I can bypass oil from going to burner and shutting down. Thanks Joe <a href="mailto:joeboo4@verizon.net">joeboo4@verizon.net</a>
you'd be best
to call in a oil tech. The small nozzle could be plugged as well. They flood easily, and you may have air leaks that only some knowledge an a vacuum gauge can find0
