Teledyne Laars EBP-110 LO message
merc476
Member Posts: 1
Hi,
I've had this unit for about 8 years now. Within the past year, every so often maybe twice a month, I would'nt get hot water so i'll go down and see the "LO" message on the boiler. I hit the reset button and then im fine. Just recently, it's become an every day thing. In some cases, the temp will just be at about 090 or it would just say "LO". If it's on "LO" I just hit reset and it's fine. If it's showing a low degrees like 90, I have to shut the boiler off for a few minutes and turn it back on. Any idea what can be causing this? I searched the site and saw a few posts back in 2008 but didn't seem to have any answers. Thanks!
serviced
Have you had a service tech in to go over your unit? Without proper testing equipment, your only going to be guessing what part is failing. All gas equipment should be serviced and inspected. 8 years is a long time without..0 -
Circuit board
I have had to replace a few circuit boards on those units.0 -
LO=Lockout
LO is Lockout, combustion related, 3 failed ignition attempts results in LO
Meaning it could be just about anything requiring a gamut of testing tools to discover the problem, not quite a DIY diagnostic0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
