Lanair
BWeaver
Member Posts: 9
in Oil Heating
Does anyone out there know where I can get parts for a Lanair waste oil furnace. The o-rings is really what I need. I can get new blocks from Lanair, but it seems I should be able to get just the o-rings somewhere a whole lot cheaper.
Have to be careful.
O-ring material is very dependent. All o rings are not created equal. You have EPDM, Buna, and a whole lot of other compounds. The compound is chosen for the substance that the o ring is sealing against.
Waste oil can contain different petroleum distillates. So the o rings are specific to seal against everything from transmission fluid to Delo oil.
Just be careful or you could have mess on the floor.
Good Luck0 -
sometimes
Cheaper is not always better...0
