Bosch Tankless Hot Water Heater Problems
hairball
Member Posts: 19
I have a Aquastar 125FX that I installed about 4 years ago. With the water off the burner will still try to ignite or a few times I would get no hot water because the unit would try to ignite but the burner would not start to burn. I had one small issue with the micro switch the first year I had it but a adjustment fixed the problem. Now adjusting the micro switch will help but the problem will come back. I did order a micro switch but I am just guessing that is the problem right now. Anyone know how to deal with these units?
Bosch
If nobody can give you specific answers, take a look at this thread. It has the contact info. for Bosch tech. support.
http://www.heatinghelp.com/forum-thread/137284/Bosch-Tankless-Problem8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
