Black Eye
NickM
NickM Member Posts: 25
Below you will see the Weil Mclain oil fired boiler which keep s me up many of nights.Last year I had it down fired and added new controls which saved me 15% of my oil ussage. FANTASTIC
It is run in the summer for domestic hot water but about a month ago it went into "lockout" and refused to recycle.  After inspection it was found that the eye which sees fire was blacken with soot/oil.  It was cleaned , but last night it went into locklout again.
What should I be looking at ?
This is a symptom for what bigger problem ?
Why all the soot and unburned oil ???
Any thoughts ?
Regards
Nick
    Steamhead Member Posts: 18,207
    It shouldn't do that
    you may have a draft problem, lack of combustion air, wrong nozzle, wrong head setting, etc. Get a real pro in there.
    Consulting
  • NickM
    Elimination
    It theer anyway I can eliminate some of the possibilities?
    This boiler was "tunedup" when I had the nozels changed to down fire it
    and was running great though the winter and spring
    Thanks for responding
    Nick
  • NickM
    Elimination
    Nick
  • Robert_25
    Robert_25 Member Posts: 555
    Sooty burn
    So this started after you had the boiler downfired?  I'm going to guess that the burner wasn't properly adjusted after the nozzle was swapped out.  There is also the possibility that the nozzle is not the proper angle.
  • Greg Maxwell
    Greg Maxwell Member Posts: 210
    Black Eye
    You need to get someone in there do do a proper cleaning, and combustion test. After that is done, your problem should be solved.
