How To Flush Out Old FHW Radiator
Steve_166
Steve_166 Member Posts: 11
Just purchased a slenderized fhw radiator to replace one that had froze/split in an old funeral home. The used on I bought comes from a fhw system as well. Pulled the bushings and it has a lot of sludge in the base of it. I am going to hit it with a wet vac and try to blow it out with a hose. I was wondering if there is a chemical I should add to it to really get it clean. I don't want to risk damaging this one, I picked it up for $75 and it would run me at least $700 everywhere else I called.
  • Steve_166
    Flushed With Water
    Okay, so far I have vac'd out as much as possible and then adapted a garden hose. I blew it out until it runs clear and pressure tested at the same time - no leaks so far. Still wondering if there is something I should treat it with prior to installing it.
  • Greg Maxwell
    Greg Maxwell Member Posts: 210
    Radiator Flush
    Try Tri Sodium Phosfate.
    Steamhead Member Posts: 18,502
    If the water is running clear
    no more flushing is needed. You should be good to go.
    Consulting
  • Jean-David Beyer
    Jean-David Beyer Member Posts: 2,666
    TSP
    Trisodium phosphate is traditional for this, but if you happen to have any aluminum in your system (e.g., a mod-con with aluminum heat exchanger), you do not want to use TSP because it is difficult ot get it all out. And any residue of TSP will ensure corrosion of the aluminum. Or so the manufacturer of my boiler says.
  • Steve_166
    Thank You
    Thanks for the suggestions. I ended up deciding to just flush it good (both ways) until it ran clear. I'll look into the TSP for the future though.
