studying for R-410A test
i have 2 questions.
1. the federal clean air act calls for the phase-out of HCFC-22 in accordance with? is it just me or is that worded really funky, because i do not understand that
and 2. evaporating pressure is also known as?
  • Techman
    Techman Posts: 2,143
    edited July 2011
    Protocol!
    -in accordence with the Montreal Protocol ? Kyeto Protocol ?  #2-boiling point of the freon? Suction press? Lo-side press?
  • edow
    edow Posts: 17
    more 410a questions
    i just had a DUH moment with the Montreal and Kyeto Protocol
    A mineral oil refrigerant system that is retrofitted with an HCFC refrigerant blend?
    thats the question. what the hell does that mean!?!?!?!?!
  • edow
    edow Posts: 17
    im going to drive you guys nuts with all my questions throughout the day
    DOT 4BA 400
    DOT i know is deparment of transportation
    i believe the 400 means the cyclinder is rated for 400 psi
    what does 4BA mean?
  • Techman
    edited July 2011
    Think about it.
    Mineral oil is "used to be " in ACR now adays. So that's old stuff ! The HCFC class is generally a " blend",including  r22, is an" Interim refrig" ?????Might need the oil to be changed, depending!
