Radiant Slab Sensor
MTR
Member Posts: 8
Does a radiant slab sensor have to be embedded directly into the concrete? I was planning on running a 1/2" pex line down the wall and into the slab for the sensor wiring. Was wondering if I could cap the end of the pex and put the sensor in the tubing itself. Figuring in the future if it went bad, I could pull it out and replace.
sensor
I have installed them that way. It will work fine.
090 sensor should have concrete conection for proper operation.0
- 117.4K All Categories
- 82.7K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 401 Carbon Monoxide Awareness
- 7 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 106 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 675 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.2K Strictly Steam
- 2.9K Thermostats and Controls
- 47 Water Quality
- 31 Industry Classes
- 64 Job Opportunities
- 11 Recall Announcements
