Plug removal from boiler
Paulien
Paulien Member Posts: 7
Feel a little silly posting this.. however does anyone have a simple solution to removal of a plug in a new Burnham Boiler?? Don't know why they don't put a nipple & cap to make life easier..!!
    Steamhead Member Posts: 18,203
    Impact Wrench
    works well for us.
    Consulting
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    two sizes larger of a wrench
    than you would use to install it if a 14" would work use a 24" if it calls for a 18" use a 36" or what Steamhead said.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • jim s_2
    jim s_2 Member Posts: 116
    Is it a recessed type plug?
    If so good luck,I`ve snapped breaker bars trying to get those things out and ended up having to drill and fillet the stupid things.
    Complained to Burnham but to no avail.
  • haventseenenough
    haventseenenough Member Posts: 61
    plug
    That plug may have been installed for a reason. Why does it need to be removed? And can the need be solved with outside of the boiler piping?
  • haventseenenough
    plug
