whiskey distillery room heat
eyeoree
Member Posts: 1
have to heat a fermenting room (no people) to 140 Fahrenheit for short periods with
buderus panelrads how do i size them
thanks,
mike
thanks,
mike
Sizing
You've got to find a heatloss program that lets you enter a 140 degree room temperature. My Slat-Fin Heatloss Explorer only lets me go up to 90 degrees.
Give us the room information. Maybe someone has a program that will work or we can do it long hand. We'd need: room height, length, width, square feet of windows, single or double pane, how many exposed walls, R-value of wall insulation, square feet of exposed walls, ceiling insulation, is there a roof above or another room, floor construction (slab, raised floor, room below, etc.), insulation in floor.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
