Boiler savings
Happ
Member Posts: 1
I am trying to find cost savings numbers, we have 4 burnham 808-B boilers hooked on a common header used for building hydronic heat and am looking to see what kind of cost savings there would be it we went with the newer Peerles purefire boilers PF399's and would we need 4, the old burnhams run are about 13-14 years old run about 83-85 % efficient and the Peerless run about 95% any help in crunching numbers would be appreciated.
Find A Viessmann
Distributor in your area. Viessmann will provide a cost and savings analysis. They will come in evaluate the existing system and compare that to theirs as well as competitors. Make sure you have atleast 2yrs worth of fuel bills also. Where are you located?There was an error rendering this rich post.
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 971 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
