600 series
gman6785
gman6785 Member Posts: 1
I have a 600 series Mt. Hawley boiler. I tried to turn it back on this weekend with the cooler temps. The water gets heated up and the motor engages but the pump doesn't circulate the water through the pipes. I checked the oil fill areas and they all had oil in them. I can see the coupler pull the springs tight but it doesn't want to turn on the other end of the coupling. Is there anything I can do myself to get this to work? Thank you,
