Who Has Siggy's HydroniCad
CMadatMe
Member Posts: 3,086
I recently purchased HydroniCad with the 3rd Version of Modern Hydronic Heating. I was a little disappointed that there was not a Low Loss Header or a Buffer Tank in any of the palletts. Its a must for me. Am I missing somthing. I've searched everywhere I can think of in the program and cannot find them. Also did not see any links within the software for updates. I also purchased the HDS software which I love and have used quite often.
Build the components
I start with the blank tank and add the ports, air vents, etc. With the jagged line symbol you can add heat exchangers inside the tank.
For a LLH I stack the closely spaced tee symbol, which is what a low loss header really is
hrBob "hot rod" Rohr
Living the hydronic dream0 -
Be Creative
Thanks HR. I'm understanding. New software always has its little in's and out's. So the software allows flexibility to be creative. That is a nice feature. I was thinkng it was limited to what was offered in the palettes. I'll play around with it in a different light. Any other hints I should know about? Thanks again..There was an error rendering this rich post.
Software
Hey Chris, you can reach out to Siggy by phone or e-mail, I have the HDS & Heat Load Pro, and anytime I had a question on either one he always returned my call or e-mail to help me out.0 -
to build HX tanks
I use the "polyline" from the drawing tools. HydroniCAD is a nice quick, colorful, inexpensive hydronic and solar program. It's not really intended to compete with Visio or PowerCAD.Bob "hot rod" Rohr
Another Question for Hydronicaders
I can delete items right after drawing them. Is there a better way to delete things from several moves earlier or from an existing drawing? All I can do to make unwanted items go away is to drag them off the page.0 -
Thanks Guys
I want to thank all that gave helpful hints. I appreciate it.There was an error rendering this rich post.
deleting items in HydroniCAD
To delete an item in HydroniCAD, click on it to select it, then press the delete key.
siggy0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
