Hydraulic Institute Looking for System Savings Examples for Industry Awareness
Fellow Wallies, I need help on this one...
The Hydraulic Institute is looking for overall SYSTEM energy saving examples (heating or cooling) where a pump retrofit was performed. I have a lot of documentation and case studies on pump electrical savings but very little on overall system material. This is required for various reasons including an HI Systems Standard and the HI Utility Rebate Task Team.
Do any of you have this information or where I can look? This is way up there on the importance scale - any help would be very much appreciated...
More information on the Hydraulic Institute can be found at the following links:
<a href="http://www.pumps.org/">http://www.pumps.org/</a>
<a href="http://www.pumpsystemsmatter.org/default.aspx">http://www.pumpsystemsmatter.org/default.aspx</a>
Here's a WILO success story you can use
http://www.heatinghelp.com/forum-thread/131327/WILO-pronounced-Vee-lo-savings-updateAll Steamed Up, Inc.
Consulting0 -
Lets Not Forget Our Friend
Mr Yates and his remarkable savings in his own home. Article is attached..There was an error rendering this rich post.
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 379 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
