Ph testing of solar circuit
DD_5
DD_5 Member Posts: 36
It's time to go out and maintainance check  the solar installs I did a couple of years ago. Both are closed loop Caleffi systems with Dow glycol.
I need a reliable, easy to carry, cost effective test kit for Ph etc...
Any suggestions?
    hot_rod Member Posts: 28,291
    here are some choices
    check here for the glycol tester to show freeze protection. Shop around prices vary.
    www.misco.com/category.php?categoryid=24
    For ph I use a Hach electronic pocket meter. Extech is another brand in the 100 dollar range.
    hr
