Removing asbestos and a cold snap
1902Shingle
Member Posts: 22
We're having our deteriorating asbestos removed this week (they started today) and of course its freezing outside today and tonight is suppose to be cold. Will I do any damage if I turn the heat on this evening while the pipes are naked? We have a single pipe steam system. I know I'll hear banging but will it be ok for a few days? Its suppose to warm up by weekend. Thank you!
Pipes bursting?
I would be worried more about your pipes bursting if your saying its below freezing outside and they are no longer insulated. I can't give you an answer to your original question as I have limited knowledge in this field. Hope this helps.0 -
Its not going to be that cold, mid 30's and the pipes are all in the basement which won't get that cold in a day or two. We also have steam so a burst pipe is an unlikely outcome. Thank you though!0 -
you will...
be fine. It just will take longer to come up to temp and you may have some water hammer.0 -
Cold Pipe
You probably won't get any steam hammering, but you will surely have a warm and toasty cellar or under-floor crawl space.
Crank the heat. Be warm and comfortable.0 -
Thank you
awesome, thank you! I think the negative pressure sucker fan things (that's a technical term) are sucking cold air into the old girl from every gap in windows and doors it can find, lol.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 919 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
