Things don't stack up right
Techman
Skeleton frame motors.One motor has 19 plates in its stack and it's amps rating is .50a , # 2 motor has 31plates and its rated fpr .50a ,& #3 motor has 23 plates and it's amps is .65. All are 115v. All are same mfrg. How can this be ???????????????????
Ask your doctor
if Viagra is right for you."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Stack up
Brad,HO HO ho !!0 -
Are these motors in service, or in the back of your truck?
If these motors are in your truck or shop, give them to Francisco to bring to me. I'll have the boys check 'em out for you.There was an error rendering this rich post.
Skeletons in the closet[ the back of the truck] .
Mr. D.O.T. gave me a ticket for overweight, by visual observation . So, I've spent some CONSIDERABLE TIME going thru EVERYTHING and down sizing ALOT . What a PITA.!!!!!!. So going thru my stuff , I was going over the skeleton motors section, and found this dielima in front of me ! Which motors do I sacrifice back to inventory !0
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
