Drainback booster pump question
Interceptor
Interceptor Member Posts: 46
I'm putting together a 384 square foot drainback system with approx 25 feet of vertical head, plus piping and collector loss. I'm planning to use a Tekmar 157 pump controller. The 157 can operate a booster pump to help fill the collectors at startup. In an effort to reduce energy consumption I would like to use a large pump as the booster and a smaller pump to continue circulation after the return siphon is established. Is there any problem with using two different size pumps in series for this application? I assume the larger pump should be pushing through the smaller pump to avoid cavitation?
    hot_rod Member Posts: 27,838
    it should work
    I ran my system with a Grundfos 15-58 and an Alpha paired together. The 15-58 would drop out after 3 minutes and the Alpha would run the system with about 20W of energy.
    I switched to a Grundfos 15-100 on variable speed drainback function, mainly to free up one of the relay outputs. Dual drainback pumps require both relay outputs in the control.
    I use that second relay to shuffle to the hot water tank.
    hr
  • Kevin_in_Denver_2
    Kevin_in_Denver_2 Member Posts: 588
    15-100
    HR,
    Then what wattage does the 15-100 use for steady state pumping?
    current draw
    1.1 amp. For drainback it runs 100% speed until the siphon is established, then it modulates bases on delta T between the collector and tank.
  • Interceptor
    pumping efficiency
    I was going to use one large pump and just let the controller modulate the speed, but I had concerns about the efficiency of a large pump running at a very small percentage of it's rated capacity. I believe it's better to keep a pump operating as close to it's design curve as possible. A single large pump would only run in it's "sweet spot" for 3 minutes out of the day. My thought is that the pump should be sized to meet the whole day circulating requirement, not the 3 minute startup load, hence the need for two pumps in this type of system. A small variable speed pump that's closely
    matched to the circulating requirements of the collectors, and a large
    one on a timer to fill them at startup. I understand the pump curve changes as the motor speed changes, but the curves are not documented for anything but full speed (Grundfos Alpha excluded). The impeller and housing on a single speed pump are designed for maximum efficiency at full speed, who knows what happens to the mechanical efficiency when you slow them down.
    I have Taco 005 and 0011 stainless pumps that I bought for this purpose. They looked good on paper, but seeing the two side by side and realizing how different they are in size made me wonder if it's a good idea to have them close coupled in series.
    edited April 2011
    inefficiency is the name of the game
    with wet rotor circs. At best they are mid to high 20%. I did test the pumps on a solar control with variable speed control. At 50% speed they do not consume 1/2 the energy. it's not a direct ratio.
    If you have a flowmeter in the circuit and an amprobe you can calculate that efficiency under actual conditions. Here is a link to Siggy's article with the formulas
    www.pmmag.com/Articles/Column/478f1350f4fc7010VgnVCM100000f932a8c0____
    www.pmmag.com/Articles/Column/9b2042f2480d7010VgnVCM100000f932a8c0____
    If uber efficiency is the goal, I'd look at one of the ECM's like the Alpha. Chose the fixed speed that matches the flow you need. I suspect you will use 40- 50% maybe less energy than a typical circ.
    hr
