Boiler PRV/backflow
Harvey_2
Member Posts: 27
Where the PRV/backflo preventer tie into the system between the exp.tank & air scoop, is it best practice to put a ball valve between the water supply and the backflow and another between the PRV and the connection to the system? THANKS
yes
it isCost is what you spend , value is what you get.
cell # 413-841-6726
extra valve
Absolutely...sure makes servicing or replacing it a lot easier, especially if at @ 2 AM on a cold night....0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
