Antifreeze
October Home
October Home Member Posts: 75
Hello,
Please remind me. Is there an ICC code that says that boilers with installed antifreeze must be labled as having anitfreeze?
Best to you all, Arlene
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Hi Arlene :-)
    I don't think the code requires labeling so long as the fluid is non toxic. Common sense says it should be labeled that it contains antifreeze to keep a new, unknowing, unsuspecting first year technician from dumping thousands of dollars worth of antifreeze down the drain.
    Good to see your words here.
    ME
  • October Home
    edited April 2011
    Thanks Mark
    I've recently read an article you wrote about antifreeze. I guess the lable thing was something I heard and thought it was codified somewhere.
    best regards, Arlene
