Boiler serial numbers
Ron Jr._3
Ron Jr._3 Member Posts: 605
Do any manufacturers actually stamp or cast the numbers in the boiler block anymore ? My partner used Spray Nine on a boiler we installed and the numbers just disappeared . Had a hell of a time tracking down the serial from the supply house .........
Welcome
It looks like you're new here. Sign in or register to get started.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,417
    When I get large weil boilers
    They are just assembled from inventory of Webbs. The serial number is really just the jacket. The block is picked out the pile for what you want as in so many centers with or without tankless ports. SO I would think the answer is no. A stamped plate would be nice. I have started putting serial numbers on my billing so I can access them at the shop if something comes up.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • Ron Jr._3
    Thought I remember seeing
    some numbers in the front block casting of some boilers . I could be wrong about that . I know a few steel boilers that had a plate welded to the block . And many had the good ol' stamped plate on the boiler jacket . We write down the serial number on our completion form at the end of the job .
  • lchmb
    lchmb Member Posts: 2,997
    Energy Kinetics
    Memory serves me right System 2000 welds a plate to the boiler.
  • Jim Hankinson
    Jim Hankinson Member Posts: 98
    EK serial numbers
    That plate doesn't have the complete serial number but there's enough to determine year of mfr and it has the last 4 digits of the serial number. From that we can usually determine who bought it and when.
Welcome
