Aquastat
oldbobcat
Member Posts: 9
Is there any book that will give me the specs. for residential aquastats? Also can I use a RIB to switch on off a small taco circulator?
Aquastat
Another link:
http://customer.honeywell.com/Honeywell/UI/Pages/Catalog/ComponentCategory.aspx?Catalog=Homes&Category=Single+Function_3637&ChannelID={2EB2F178-20ED-44E0-97FB-CCFB4218DD64}
And yes, you can control a pump with a RIB. Perhaps more expensive, I prefer to use a relay specific for hydronic heating like a Taco SR501. The wiring is easy and the diagnostic lights make it simple to troubleshoot.
http://www.taco-hvac.com/uploads/FileLibrary/SR501-845RP102-105.pdf8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 125 Chimneys & Flues
