Give me your best ideas
Steve Fontas
Member Posts: 26
Requirements are to make DHW for 6 adults 3 children, bathtubs, laundry, etc. Here's the kick. <strong>no space heat is required.</strong> Solar is already in the equation (120 gal storage) so what is your back-up? My gut tells me tankless is going to put quite a drain on the pocketbook. What do you folks think?
What fuel source...
What are the associated fuel costs, and what kind of dump loads are you trying to handle?
Then there's the pocket book issue. You can pay for efficiency now and not pay for inefficiency in fuel costs over time, or you can get by inexpensively, and pay continuously for your up front decision.
You can't have high efficiency and low upfront budget costs. The two do not coincide with each other.
Personally, if natural gas were available, I'd use THE highest efficiency product available that would meet the needs.
And don't forget to take into consideration the 1 man 5 woman Olympic swimming pool sized jacuzzi that they intend to fill 2 times per year... (Got storage?)
ME0 -
Gas is the fuel...
dump load?There was an error rendering this rich post.
dump load
How many gallons a minute will be your worst case that has to be met? Oh, and total gallons needed in any worst case time period.
I would guess if you need no space heating you have a large available amount of solar ?0 -
No space heat needed due to the design of this house
Worst case for DHW maybe around 18 gpm That's three old school showers going at once... Could be a little higher if the decide to do laundry at the same time.There was an error rendering this rich post.
Wow....
18 guppies per minute is a LOT of fish...
18 * 8.33 * 100 * 60 = 900,000 btuH OUT put from the water heating device. That pretty much eliminates any small residential electric heaters.
Let's keep crunching numbers. If their showers will be equal to the national average, then 10 minute duration means 18* 8.33*100*10 = 150,000 tbuH output.
Divide that number by the combustion efficiency, altitudinal derate if you are above 2000' and throw in a 30 gallon reverse indirect (Turbomax) and you're cooking with gas.
Dump load actually pertains to a fixed quantity of water, like a 120 gallon soaking tub that needs to filled in short order, as opposed to taking an hour to fill.
ME0 -
Thanks for the input Mark
Electric was never an option. We are in NYC. Electric heating here is a dirty word...There was an error rendering this rich post.
whats your plan?
how much "back-up" do you think you need? WE are from all parts of the country so we can't 'see' what your need is??
what percentage do you think the solar can handle?
if its major, gas/oil makes sense, if its minor, electric makes sense. certainly solar could handle the whole thing, depending on available sun . all depends on size.0 -
Not quite sure
What to make of your post jp. What I am asking is simple. What would be the most economical back-up for a solar thermal system making DHW only. Gas is the only fuel option. The system has a 53% solar fraction and 120 gal of storage. It is located in NYC. Would you use tankless? A boiler? Solar cannot handle 100% nor should it or I would have a major problem on my hands in June. Now I wish the solar fraction was better, but I am just trying to help a customer that may be getting shafted by someone else..There was an error rendering this rich post.
Define economical...
First cost economics or long term operating cost economics. THe two, as I said before, don't usually ride on the same bus together...
The least expensive "item" that would have the ability to keep up with the Joneses showering/bathing habits would be a big ol' tankless, like a Takagi Mobius or equal. Lots of btu's in a relatively small box.
The least expensive "Item to operate would be a good condensing water heater, of which there are numerous on the market, but they will not be cheap.
ME0 -
Thanks for all the input
Mark, do you have a preferred condensing water heater?There was an error rendering this rich post.
Knight Lochinvar...
coupled with a reverse indirect. Treat the DHW heater as a space heating function, and it gives your control logic a lot more flexibility. Use a 10K sensor at the tank instead of a bang bang aquastat so the intelligence of the Lochinvar can "see" what's really going on in real time.
For reverse indirect, I'd use a Thermomax at www.thermo2000.com
As I posted in another thread, if you can do some real time monitoring, you can fine tune the need for BTU's, and possibly down size the physical plant.
go here http://www.heatinghelp.com/forum-thread/136081/Fitness-club-dhw-retrofit-Pro-advice-needed
ME0 -
Thanks Mark
You're the man...There was an error rendering this rich post.
De nada...
Pay it forward :-)
ME0
- 120 Geothermal
