On top radiant heat
Hub
I want to use radiant floor heating in a new house that's rather large. I
want to install it myself, and have contacted several suppliers. Right
now, my intention is to install the tubing above the sub-floor, with 7"
wide strips of wood spaced 3/4" apart. Obviously, the aluminum plate and
tubing will fit into the slot created by the 7"wide strips. I plan to
cover this layer with plywood, then the floor covering, some of which
will be linoleum, and some....... carpeting. The reason I want to use
the wood strips is because I have an unlimited supply of 3/4" lumber
already in my possession. The cost was perfect........... free!! Is
there any reason not to do what I've described? I'm well experienced in
construction, plumbing, and electrical work, but having never done this
type of project before, I'm looking for advice.
dry above
HeatLink has a system like this that we install regularly, it works well with low water temps, uses plain plywood strips and three supplied components: transfer plates, end bends for curves and spacer clips to keep the pipe down in the groove. You could probably make do without the end bends and router your own curves if time wasn't a concern but the spacer clips are key, I don't know how else you would keep the pipe down, I have heard of guys using tape with mediocre results.
http://www.heatlink.ca/en/system/files/Brochure/L3350-HeatLink-DryAbove-System-Brochure-2008-03-26.pdf
fyi: for some reason the link will only save to your downloads instead of just opening
here's a video too!
http://www.heatlink.ca/en/flash/video/vid0001/video-dryabove-staple-down-system-installation0 -
if
you use a plate worth using, it should hold the pipe down by itself.Rob Brown
Designer for Rockport Mechanical
in beautiful Rockport Maine.0 -
plates
Why would a heatlink plate not be worth using? sure they don't hold the pipe down but they transfer heat just fine, I don't buy the "more mass = better heat transfer" philosophy, I have never installed an on top system using these plates that has needed more than 110 deg F on a design day.
These are awesome plates: http://www.radiantengineering.com/TFinBrochure.pdf but are a little pricey and not as available in a lot of areas.0 -
What Concerns Me
Is that I heard nothing of a heat loss and radiant design. Your post states multiple different floor surfaces all having different r-values especially that carpet and pad. Suggest before you even lay a strip you consult with a radiant pro in your area. If your budget tight and trying to save on labor and material cost but plan on hiring a pro for the mechanical room end, it would be in your best interest to consult with one now.. That's the best advice any of us can give you in my opinion.There was an error rendering this rich post.
Plate worth using
I believe Robs point is an omega style plate wraps the tube, and holds it in place. The benefit of which is the more tube wrapped by the plate. The more conduction taking place between the tube, and the plate. Some cheesy plates out there that do not even make good 180* contact on the tube.0 -
Concerns
Chris is right! Do not assume equal consistant layout centers, or water temps. When there is different types of r valued floor covering, and heat losses room to room there is not an umbrella fits all floor panel lay out.0 -
Last I Knew ThermoFin
Supplied Zurn with their plates. That was some years ago when Zurn began getting into the radiant business. At one point you could get them in 8ft lengths.There was an error rendering this rich post.
Thanks for the advice, but I've already had that done. I sent my
house/floor plans to the supplier that I'll be using, and they have
designed the layout according to coverings, windows, etc., in each of
the rooms. I'll be doing the installation myself, with the supervision
of an acquaintance who does radiant heat for a living. Although we're
not close friends, he has agreed to act as a "consultant" for me.
(parent of a former student) I think I have all of the bases covered,
but I want as much info as I can get!!0 -
that's not a philosophy
it's an incorrect statement. the mass of the plate has nothing to do with its heat transfer.
but if the plate is not holding the pipe tightly enough to hold it in place, then it has poor tubing contact and becomes much less useful as a heat conductor.
Heavy gauge plates are better because they can conduct more heat, and have much better tubing contact. Light gauge plates can be good, we use them a lot, but you definitely want one with a very good tubing groove and that means omega shapes that hold pipe in place.
If the plate doesn't hold the pipe with good contact, it's a waste of money.Rob Brown
- 135 Chimneys & Flues
- 16.2K Strictly Steam
