How Old?
Robert O'Brien
Member Posts: 3,584
Any ideas? It's off a gravity HW system we pulled out in December. Thrush pressure reducing valve and relief valve,can't vouch for the relief but the feeder was still good after what must be at least 70 years!
1940s I believe
I still see those around here once in a while.All Steamed Up, Inc.
Consulting0 -
That thrush is
about 50-60 years old. I have something for you that I will post a pic of here tomorrow. Might be older?0 -
Yours looks older than mine!
This Thrush valve set was installed in 1955 and still works perfectly. That would make this one 55 years old and it certainly looks more modern than what you have.
What's even more surprising is that the relief valve still does not
leak, even after operating the testing lever. They certainly knew how to
make a quality product back then!0
